gen to alt convertion
Old Feb 9, 2009 | 03:29 PM
2pazr's Avatar
2pazr
do i get rid of the voltage regulator thats mounted next to the battery?
any one know a good place to find a kit or a exact swap for a 292 y block
Old Feb 9, 2009 | 07:07 PM
merten's Avatar
merten
Try this web site, should have brackets, alternator and instructions for your y block.
Fifth Avenue Internet Garage
Old Feb 9, 2009 | 07:36 PM
2pazr's Avatar
2pazr
what if i were to put a alt in would i need to do anything but plug it in to the voltage regulator?
Old Feb 9, 2009 | 07:48 PM
merten's Avatar
merten
Use an internally regulated alternator, no external needed.
Old Feb 9, 2009 | 07:59 PM
Julies Cool F1's Avatar
Julies Cool F1
Alternators and generators use different regulators so if you buy an alternator that requires a regulator you'll need to buy one.
But, as suggested, I would definately recommend you buy a "one wire" or GM style alternator that has the regulator built into the alternator housing. Get rid of that ugly regulator AND all the wiring!
I have one and it's fantastic. I got mine at "Tuff Stuff" for about $125. The instructions were very good and clear, and the tech service guys were great!
Here is the link to "Tuff Stuff:"
Products :: Tuff Stuff Performance
Old Feb 9, 2009 | 08:04 PM
2pazr's Avatar
2pazr
did you need a special bracket to install it? how did you run the ignition? just staight to the starter silinoid?
Old Feb 9, 2009 | 09:25 PM
Julies Cool F1
Well, no, But I have a 390 in my truck and I bought a polished stainless steel bracket so it would be "pretty." If you call the tuff stuff guys, they know what you will need, and if they don't have one, they will make one - probably have brackets or know where to get them too.
Ran that one wire right to the BATT terminal of the starter solenoid! Ignition stays the same!
J!
