Need help!
Old Feb 9, 2009 | 12:45 PM
jasonneedshelp's Avatar
jasonneedshelp
Need help!
Hey guy i need alot of help this weekend i blew up my 96 f150's 302 :' ( .
My question is i have a running 429 in my garage what will it take to drop it in my truck? its a 3 speed auto+ overdrive?
thank you for all your help i need it!
jason
Old Feb 9, 2009 | 01:48 PM
jasonneedshelp
I would need a c6 tranny wouldnt I?
Old Feb 9, 2009 | 02:40 PM
Conanski's Avatar
Conanski
You basically have to strip that '96 bare, remove the complete powertrain and engine wiring harness, get big block engine mounts, front springs, and tranny, bolt it in and create a drivesahft to fit. Then you need to install a low pressure fuel system, an ignition system, and figure out what wires under the dash you need to connect the gauges to the motor and turn everything on at the right time. It's certainly no weekend project.
Old Feb 9, 2009 | 03:07 PM
Kemicalburns's Avatar
Kemicalburns
i would follow all steps it takes to install a 460. you can even take all the efi 460 hardware and try and go that route. either way its work and not a drop in and go swap.
chard17
1997 - 2003 F150
Mar 25, 2014 06:10 PM
cody jessen
General Diesel Discussion
Apr 17, 2013 09:36 AM
bigwillwrx
Sep 1, 2011 06:50 PM
BlackBeast24
2004 - 2008 F150
Apr 1, 2011 10:53 AM
Boonebird
20
Apr 2, 2008 07:08 PM
