t-case troubles
Old Feb 8, 2009 | 11:57 PM
dragonmaster093's Avatar
dragonmaster093
t-case troubles
Hey guys Well things with this truck just dont seem to get better here aftrer getting front diff fixed the shop that did it drug the truck around while waiting for parts with a bob cat. Dont know how but they screwed up the transfer case so now im hunting down a t-case the one i there is making all sorts of nasty noises and growls in 2wd. needed to replace hubs they scewed them up would not lock or unlock so if any one knows of a divorced t-case or has one they would part with please contact me at dragons_lair59@yahoo.com or if any one knows where to get a good rebuild kit these cases ive been told are gears not changed also can a married style be converted thanks
Old Feb 8, 2009 | 11:59 PM
jcduerr's Avatar
jcduerr
fix the font please ( un bold it) and ill be happy to re-read your post
most likely its a NP205 transfer case, use google or ebay for a rebuild kit. personally i cant see that draging it around with a bob cat causing the problems you describe.
"the one i there is making alsorts of nasty noises and grows i 2wd" rephrase this please
not sure how the hubs got messed up by them dragging,pushing or pulling. ( i leave my hubs locked in all winter and the transfer case in 2wd and have never had a issue
for a new or use t-case check ebay
Old Feb 9, 2009 | 12:00 AM
garypettengill's Avatar
garypettengill
When I had my truck apart I rebuilt my transfer case, no previous experience. Did fine. All the parts are still available.
Old Feb 9, 2009 | 12:23 AM
75F350's Avatar
75F350
That is difficult to read.
I dont understand how a shop that had the diffs apart could have messed anything up.
Here is the thing that makes little sense. If the diffs were being workned on, then the d-shafts were probably out, so the vehicle would have just rolled around without resistance. If the diffs were not apart, and the d-shafts were still in, then the front hubs would have been unlocked, (not that this would matter either way) and zero problems would result, so the rear is connected, and all the place wold have to do is kick the trans into neutral, (or anything other than park if the trans is auto) and the thing will roll. Heak they could have put the t-case in neutral and things would have been fine. even if they did not, nothing should have happened.
I flat tow my 73 (on 44's by the way) and this cant be any different than tugging it around the yard with a bobcat.
Something else has to be wrong. This stuff cant just break. If you have a 205 t-case, it is a bullet proof case and will take more than what you described to damage it.
Regardless, re-build kits are available from a few of our sponsors. Here is a link to a bearing and seal kit:
NP 205 Bearing And Seal Kit
As far as your lockouts go, they are either busted or they are fine, these work or they dont. Maybe they could use a cleaning, or they were installed incorrectly, and they will not engage.
Old Feb 9, 2009 | 12:24 AM
dragonmaster093
not sure either but when it went in everything was fine git it back and 4 didnt work wouldnt shift to low or neautral and t-case worked fine with no noises
Old Feb 9, 2009 | 12:51 AM
jcduerr's Avatar
jcduerr
if the tranny and t case have been removed( dont take this the wrong way) but grow some ***** and push or pull on the 4x4 stick like you mean it. mine is a bit difficult after i changed my flywheel just takes muscle and it goes in fine now
