Code reader
Old Feb 8, 2009 | 09:15 PM
7.3 Rocket's Avatar
7.3 Rocket
Code reader
Where can I get a code reader that will read codes from a 7.3 and 6.0 at the least?
Where and what price range? We've got 3 PSDs and it should be another on the way. It'd be a nice addition to the shop.
Old Feb 8, 2009 | 09:19 PM
fxstbchopper's Avatar
fxstbchopper
This will take care of what you need.
AutoEnginuity PC Scan Tool (USB)
Old Feb 8, 2009 | 09:22 PM
7.3 Rocket's Avatar
7.3 Rocket
And what if I'm not willing to take my laptop into a greasy shop? Any other options?
Old Feb 8, 2009 | 09:30 PM
fxstbchopper
Then your going to need at least 2 code readers.
Edit: To get something other than AutoEnginuity to read for a 7.3 and a 6.0 it would take a programmer with code reading for each truck no body makes one compatible with both engines.
Old Feb 8, 2009 | 09:41 PM
7.3 Rocket's Avatar
7.3 Rocket
Alrighty. I suppose I could use that program with a cheap laptop from Best Buy. I can't seem to find any minimum system requirements for a laptop on that site so I assume any PC will work.
Old Feb 8, 2009 | 09:45 PM
fxstbchopper
From their web site.
Requirements
Windows 98SE 1/ ME / 2000 / XP (Pro, Home, and Media Center) / Vista operating system
32 MB of free drive space
CD-ROM or DVD-ROM
32 MB of memory
1USB 2.0 support is required for operation (regardless of USB or serial support being purchased). USB 2.0 is built-into Windows 2000 and later.
AutoEnginuity® - OBD2 Scan Tool - Professional PC and PDA Diagnostics
Old Feb 8, 2009 | 09:56 PM
7.3 Rocket's Avatar
7.3 Rocket
Thanks again, Tracy.
I found a 350$ Toshiba laptop at Best Buy that fits the bill nicely.
So somewhere around 700$ to get everything set up. Seems reasonable enough to be a possibility.
Old Feb 8, 2009 | 09:59 PM
STROKIN'IT7.3's Avatar
STROKIN'IT7.3
never thought of buying a cheap laptop to get greasy... a very good idea since my laptop has all my school work on it... great idea
Old Feb 8, 2009 | 10:04 PM
fxstbchopper
No problem Pete. It will be a very good investment.
7.3 Rocket's Avatar
7.3 Rocket
Yea. I really don't want a greasy 1300$ Dell.
This one should fit the bill.
Toshiba - Satellite Laptop with Intel® Pentium® Dual-Core Processor T3400 - Matte Silver - L305-S5920
Old Feb 8, 2009 | 10:07 PM
phatdually1's Avatar
phatdually1
Smile
You could log on to ntx tools and they have a scanner called a nemysis that will handle any diesel truck up to 2009. This scanner will not only read your codes but will put it through a series of tests by checking all your injectors one by one and every other part of your system for only $531. Wiull also check cummins and duramax. Check it out you will be surprised.
Old Feb 8, 2009 | 10:13 PM
fxstbchopper
AutoEnginuity does the same it is not just a code reader it has a lot of functions and test it can run.
Old Feb 8, 2009 | 10:42 PM
phatdually1
Dont need laptop with nemysis and one scanner will do the job if you dont want to use a laptop.
Old Feb 9, 2009 | 06:02 AM
tjc transport's Avatar
tjc transport
i ain't rite
here you go Pete.
these work good
Amazon.com: AutoXray EZ-Scan 4000 Scanner: Automotive
