Bronco II Ford Bronco II
Oil Additives
Old Feb 8, 2009 | 04:12 PM
baddmove's Avatar
baddmove
Oil Additives
A long read..but worth it..
https://www.ford-trucks.com/article/..._Negative.html
Old Feb 9, 2009 | 01:47 AM
kernel-panic's Avatar
kernel-panic
I've seen articles on additives before. Personally, the only additive I have ever run was the Rislone stuff that is supposed to keep things cleaner and prevent build-up. The safest bets IMO are to use the recommended viscosity oil, a Purolator or Wix filter, and change your oil and filter regularly (using engine flush on high-mileage engines is a good thing) OR do what I did - switch over to Amsoil.
Old Feb 9, 2009 | 08:29 AM
HappyJack's Avatar
HappyJack
I don't use engine or tranmission oil additives. I do use a bottle of fuel system cleaner every oil change. Good article. Thanks for the link.
pawpaw
Oil & Lubrication
Jan 24, 2017 08:43 PM
Ford-Trucks Editors
2009 - 2014 F150
39
Oct 2, 2011 07:27 PM
yellow truck
Jun 4, 2011 09:41 PM
KenB
General Automotive Discussion
116
Nov 21, 2010 07:02 PM
jimandmandy
Oil & Lubrication
Feb 25, 2003 08:48 AM
