Sponsored by: Auxito
Signal Mirrors
Old Feb 8, 2009 | 02:38 PM
dadlovesfords's Avatar
dadlovesfords
Signal Mirrors
Does anyone know if the wiring is there for the signal mirrors on a 2000 XLT S Cab that didn't have signal mirrors to start with? I found a couple of OEM ones for a good price and was wondering how hard it is to wire them in?
Thanks , Larry
Old Feb 8, 2009 | 06:43 PM
torkum's Avatar
torkum
I don't think the signal mirrors came out until 01.
Check this out for the same option Muth Mirror Systems, LLC
Old Feb 8, 2009 | 07:06 PM
shorebird's Avatar
shorebird
The wiring is usually in place for the options. But even if it isn't the wiring could be run in an hour or two for them.
Old Feb 8, 2009 | 07:47 PM
b2747's Avatar
b2747
Easy to install. Put both sides in my 97 F250LD. b2747
Old Feb 8, 2009 | 08:02 PM
dadlovesfords
Thanks for all the info guys! I think I'll go ahead with the project.
Thanks again ,Larry
Old Feb 8, 2009 | 08:08 PM
firefighter1416's Avatar
firefighter1416
B2747 how did you end up doing your mirrors was the wireing there already or did you have to run it your self an if so where did you tap into the turn signal at
Old Feb 9, 2009 | 08:31 AM
92merc's Avatar
92merc
Go to that link on Muth's site. They'll have an install manual. What you'll find is a plug behind the door panel. The Muth directions will tell you which ones to tap into.
The Muth kit comes with a wire you pop into an empty spot of the outgoing side of the mirror plug. Then that runs to the signal part of the mirror. So the wires go up to the plug behind the door, but don't go any further. You just tap in right there.
Or at least that's what I did on my 2003 Screw.
Old Feb 9, 2009 | 09:46 AM
dadlovesfords
Awesome 92! , that's exactly what I needed to know. Thanks again everyone for all the help!
Larry
Old Feb 10, 2009 | 08:48 AM
b2747's Avatar
b2747
Talking Signal Mirrors
The 97 F250 I have was a plain jane. I took the dash out to do this as none of the wireing was there. I bought a dash harness from a 2000 F150 that had all of the extres that I wanted, Signal Mirrors, Door locks, Electric windows, and ext door lock pad. The only thing I had to change was the speedo hookups. AS long as I had the dash out I changed the heater exchanger and installed a overhead temp gauge. I didn't have to tap into the signal system as it was in the 2000 wiring harness I also put in bucket seats and center console from a 03 F150. The interor is now done. In the spring I start on the exteror. Wish me Luck.
Old Feb 10, 2009 | 10:17 AM
dadlovesfords
Nice info B27!!
