P1506 obd code question
Old Feb 7, 2009 | 09:56 PM
uno's Avatar
uno
After getting p1506 overspeed code. Replaced iac and still have higher than spec idle ( 1100 + - ) and restarted the truck after disconnecting the battery and code is gone but high idle is still about 1100. Anyone have an idea what iam missing checked some of the top side vac hoses and they seem good.
Old Feb 9, 2009 | 07:23 PM
Gevans17's Avatar
Gevans17
try cleaning your throttle body
Old Feb 9, 2009 | 08:14 PM
alloro's Avatar
alloro
I'd say look a little more for a vacuum leak.
Old Feb 12, 2009 | 09:25 PM
uno's Avatar
uno
i THINK its a vacum leak, hard to hear the spot. replaced the IAC hoping that was it. base idle should be 780 in nuetral. idles at 1100 nuetral,750-800 in gear and lower with air - point me in the right direction pls. ever had the same type problem yourself ?
Old Feb 12, 2009 | 11:34 PM
alloro's Avatar
alloro
I've had this problem on other vehicles in the past and it was always a vacuum leak.
Old Feb 13, 2009 | 07:06 AM
projectSHO89's Avatar
projectSHO89
Drive it for a few weeks until the MIL comes back on and then re-scan it. The new fault code should give you better guidance.
Steve
Old Feb 21, 2009 | 06:44 PM
uno's Avatar
uno
hey alloro, getting back to you after new IAC and TPS code cleared..........now its back with an idle at 1100 rpm, please help if you know a good spot to check for vac leak.....or ?
Old Feb 22, 2009 | 12:41 PM
alloro's Avatar
alloro
Did you try disconnecting the battery for 10 minutes to clear out the previous idle parameters?
Old Feb 22, 2009 | 07:57 PM
uno's Avatar
uno
Thumbs up solved
after a new TPS and IAC.......my only problem was the PCV, base idle 600-650, for a whopping $3 ( finacing available with approved credit ) haha
Old Feb 22, 2009 | 09:01 PM
alloro's Avatar
alloro
Ahh so it was a vacuum leak after all.
Gerryatrics
1997 - 2003 F150
19
Mar 30, 2014 06:11 PM
pleshdog21
1997 - 2003 F150
Sep 10, 2013 06:42 AM
pfpost
1997 - 2003 F150
Aug 10, 2011 01:19 PM
firefighter1416
Feb 13, 2010 05:30 PM
