water!
Old Feb 7, 2009 | 06:43 PM
indebt's Avatar
indebt
water!
Our trucks hold alot of water when the door seals fail. I was vacuming my truck today and the carpet felt damp. When I lifted it there was about 1in of water under the plastic threshold cover. Looks like it the passenger rear leaking pretty bad. Should I get all new weather stripping or does someone have a tip?
Old Feb 7, 2009 | 06:47 PM
ron's power stroke's Avatar
ron's power stroke
there is a thread around here some place on how to slip a long 1/8 or 1/4 inch stiff hose of some sort in the rubber to stiffen it up...not sure where it went to though..some one must have it...hold tight..i think you needed to use baby powder to help make it slide in..
Old Feb 7, 2009 | 06:52 PM
rbaker6336's Avatar
rbaker6336
quite a while back I read where you could put some small hose in the seal some way to tighten it up
Old Feb 7, 2009 | 06:59 PM
big poppa's Avatar
big poppa
I guess mine are losing there form, dirt and salt are getting in my door jams but the water isn't reaching the carpet, yet. Subscribing.....
Old Feb 7, 2009 | 07:03 PM
rbaker6336's Avatar
rbaker6336
Here's one thread https://www.ford-trucks.com/forums/6...asket-mod.html
Old Feb 7, 2009 | 07:04 PM
ron's power stroke
here is another
https://www.ford-trucks.com/forums/6...-for-door.html
Old Nov 1, 2009 | 04:16 AM
rpenterics's Avatar
rpenterics
Jorge, did you end up getting this taken care of? Was it the door seals?
Old Nov 2, 2009 | 10:24 AM
indebt's Avatar
indebt
Hey Ryan, unfortuneatly the lazy factor kicked in and then the weather changed for the better. I need to get on this cuz the rains are comin!
Old Mar 17, 2010 | 11:03 AM
indebt's Avatar
indebt
Well I finally did it got off my lazzy a$$ and did the 3/8 od latex tubing in the door seals. It was a pain feeding the tube thru there but its finally done. I soaked that door for 10 minutes and no water . I'm going to do the other doors this summer! It was $1.57 per ft for the tubing at lowes, so for the price of 1 new door seal you get all 4 done. If you buy it at lowes it will be ~ $102 (with tax) or here's a link for some on ebay that comes in 10ft lengths NEW 10 Ft Amber Latex Rubber Tubing 1/4" ID 1/16" Wall - eBay (item 140385087404 end time Mar-22-10 10:47:27 PDT) You can order 4 sections and just do the center section of the door seal.
P.S make sure you have baby powder to help get it thru like pocket said! Sure you'll look like you were wresting with a cocaine bag when your done but without the baby powder you'll be sorry!
Old Mar 17, 2010 | 11:29 AM
bama29fan's Avatar
bama29fan
the plastic piece you talk about is that the offical name of it "threshold"? Im in need of one for the passenger side rear and havent found it yet.
Old Mar 17, 2010 | 11:43 AM
indebt's Avatar
indebt
bama I think its part #4 Silver State Ford Parts (Formerly DIRECTFORDPARTS.COM)Genuine Ford Truck Parts Lincoln Mercury Parts OEM Ford Parts and Accessories
I didnt realize the part was so cheap (the full weather strip @ $38 for oem, hmmmm)
Old Mar 17, 2010 | 12:41 PM
CSIPSD's Avatar
CSIPSD
I used WD-40 when I did mine... I still (2 years later) have not done the drivers side...
Wifes excursion was a PAIN!
Old Sep 15, 2010 | 11:59 AM
riverrat41's Avatar
riverrat41
Does the tubing need to be rigid or mashable?
Old Sep 15, 2010 | 12:42 PM
bama29fan's Avatar
bama29fan
squishable....like the rubber tubing they put around your arm to make your veins pop up while taking blood
Old Sep 15, 2010 | 12:43 PM
riverrat41's Avatar
riverrat41
Gotcha Shawn.....Thanks hoss
