C 4 pump removal
Old Feb 7, 2009 | 02:22 PM
NorminN.B.'s Avatar
NorminN.B.
C 4 pump removal
Can anyone tell me how to remove the pump on a C4 trans. Thanks
Old Feb 7, 2009 | 04:00 PM
rclarke's Avatar
rclarke
I lay the transmission on its back on the bench. Pull the pan and valvebody. Release the band. Remove the bolts in the pump. Use a large screwdriver or medium prybar between the sun shell and the low/reverse planet assembly. That pushes the drums forward and loosens the pump. Grab the pump by the stator support and pull it out. Hold the high/reverse drum in place. After the pump is out pull out the drums and restack the forward drums and planet assembly.
Old Feb 7, 2009 | 05:24 PM
NorminN.B.'s Avatar
NorminN.B.
Thanks, I thought once the bolts were out in front, it would come right out. Guess not. Thanks again.
Old Feb 7, 2009 | 06:49 PM
icrman's Avatar
icrman
You can do it without removing the pan if you have a tool to pull at that stator shaft, thats the nonrotating one.
