Sponsored by: Real Truck
Coil Over Conversion for 1st Gen. Super Duty?
Old Feb 6, 2009 | 09:53 PM
julio086's Avatar
julio086
Hey all,
Virgin poster here. I finally got to the position that I could afford a Super Duty (2003 reg cab 5.4) and am now looking for mods to do to it. The list gets longer by the day, friends definately help that one out.
To the nitty gritty, I want to put a coil over suspension on my front axle. The thing is, I don't want to lift it. I like how it sits now and being a short fat guy don't desire to strain myself anymore than I currently do.
I have been looking for aftermarket coil overs, but they all seem to have quite the lift to go along with them. My questions are:
1. Is there an acceptable after market coil over suspension for a first gen SD?
2. Is it possible to get the coil over from a 2nd gen and put it on or am I looking at an axle swap also?
3. Do I need to seriously look into a trade if I am set on this addition?
Thanks for the assistance guys.
--Julio
Old Feb 7, 2009 | 10:52 AM
ReAX's Avatar
ReAX
There is a fair amount of engineering that goes into a coil over suspension. The axle has to be located, by four link, three link or ladder bar and a track arm. Then the axle has to pivot on a radius, luckily though with the front axle you don't have to worry much about weight transfer so the fulcrum point isn't all that critical.
There most likely is not a stock height conversion kit. It's too much work for no change.
You could do the 05+ suspension, but you will either have to weld up the mounts or use the stock crossmember and axle. I think it would be easier to engineer your own parallel 4 link and add coil overs.
The leafs are a simple system, easy to work on, easy to lift and little to go wrong. I don't think you will see much gain in a coil over swap. These are 6000lbs pickups, not 2500lbs sports cars, major handling improvements will take more than just front end work.
Old Feb 7, 2009 | 11:01 AM
WeWonIt's Avatar
WeWonIt
I helped my buddy in Wisconsin do a simular setup on a 97 F350, he used Fabtech components, but did not order them by make and model, instead he ordered them by measurements and spring rate. I complained about the idea of removing the perfectly good leaf springs and doing all that work for a measley 2" of lift. He chewed up tires pretty bad untill we got all the adjustments right, it was a pain in the a$$. Please don't say you wan't Freightliner airbags for the rear too.
Old Feb 7, 2009 | 11:23 AM
DCSpecial's Avatar
DCSpecial
For an aftermarket setup...the Full Traction coilover conversion is the way to go, IMO. But, it's meant for a 4-8" lift. Reason being the physical dimension of the coilovers. If you were willing to cut the fender liner and relocate some things to allow the coilover to go into the engine bay, you may be able to go lower.
You can swap to the 05+ axle, suspension and steering to run coil springs.....this is not a coilover.
Smallest aftermarket setup to run a coilover is a 4.5" lift.
Old Feb 7, 2009 | 11:39 AM
Furian's Avatar
Furian
You Keep What You Kill
What are you looking to achieve by installing the coil-over system?
Old Feb 7, 2009 | 01:21 PM
Fordfanatic4life's Avatar
Fordfanatic4life
sell ur truck and replace it with a coil over vehicle...if ur set on a coil setup..
less headache in the long run..
esp if ur NOT looking to lift the truck at all...
im guessing u want the extra turning radius and softer ride ???
Old Feb 7, 2009 | 02:38 PM
ISUsuperduty's Avatar
ISUsuperduty
Lift it Julio... You're not that short or fat. Sounds like it might be cheaper to get a BowFlex so you can climb up the tires to get in it...
I'm the guy that keeps making his list longer and longer.
Old Feb 7, 2009 | 04:18 PM
DCSpecial's Avatar
DCSpecial
AMP Research Power Steps cure the height issue......
Closed:
Open:
Old Feb 7, 2009 | 08:41 PM
julio086's Avatar
julio086
Thanks for the responses guys. Guess I'll stick w/ the leafs. Like I said I wasn't looking to get to dramatic. Yeah, looking for softer ride, etc.
Old Feb 7, 2009 | 09:21 PM
Furian's Avatar
Furian
Maybe I'm slow today but I never really understood what the OP was trying to accomplish... Was he wanting the "coil springs" like the 2005 + models or was he wanting a "coil-over system" like the one sold by Icon? Both are significant converions...
Icon Vehicle Dynamics 2005-2007 FSD 7-9 Inch Coil-over 4-Link Suspension System - 2005-2007 F250/F350 SRW 4wd - Truck Toyz Store
Old Feb 8, 2009 | 03:49 PM
DCSpecial's Avatar
DCSpecial
The one by Icon works on 05+ trucks.
Different setup to convert a 99-04 to coilovers....Full Traction being the best in the under 10" of height, and One Up Offroad being the best in the over 10" of height.
Old Feb 8, 2009 | 04:30 PM
Furian's Avatar
Furian
I just posted the pic to demonstrate the difference between "coil springs" and a "Coil-Over System."
Old Feb 8, 2009 | 04:38 PM
Mustang6147's Avatar
Mustang6147
Not a big fan of coil over's Shock mounts are deseigned for shocks,(ride dampening) not suitable for lifting.
When the old style front ends (leaf spring) the shock mouted to the lower rack, it always busted at the shock mount.
Old Feb 8, 2009 | 05:09 PM
DCSpecial's Avatar
DCSpecial
The coilover hoops, towers or mounts that I've seen are all made for coilovers......I agree that I wouldn't use a shock mount to mount a coilover.
Old Feb 8, 2009 | 05:16 PM
powerstroke1350's Avatar
powerstroke1350
I think it would be possible to find a wrecked 05+ with the front suspension still in tact and throw it in there..maybe..
