I'm still looking for a set of Ford Truck Parts and Accessories manuals at a decent price. Until then I need your help with some part numbers.
What would be the part number for a set of side gears for a 1960 OA code (3.73-3.3M limited slip) differential (1960 F-100)? I located a set with the part number CODZ-4236-B, but wasn't sure if these are correct.
Also, since you seem to be really sharp on where some of these parts are located, could you pass on the locations where I can find the following parts in NOS form:
8A-2078 rear brake hose
11A-3289 RH tie rod end
11A-3290 LH tie rod end
B7C-5630-A rear spring, front bushing kit (need 2)
B7TZ-5630-A rear spring, rear shackle kit
B7C-3020 front axle bumper (need 2)
B7C-5783-A rear axle bumper (need 2)
And the following which I don't have part numbers for:
