Cam question
Old Feb 6, 2009 | 11:19 AM
dwrestle's Avatar
dwrestle
Cam question
What kind of cam would this be in a 302. TQ30H Erson Cam for a 302 Ford. Has a intake duration and a exhaust duration of .050 = 226. Has a gross lift for the intake and exhaust of 0.493, lobe center is 110. Thats all the info I got.
Old Feb 6, 2009 | 11:48 AM
Freaksh0w's Avatar
Freaksh0w
Advertised duration or real duration? If it's advertised duration, that will be a low RPM machine, while if it's the real duration, it will be more of a high RPM machine.
Old Feb 6, 2009 | 12:14 PM
Conanski's Avatar
Conanski
That's a good high rpm cam for a carb or mass air efi motor.
Old Feb 6, 2009 | 12:29 PM
dwrestle's Avatar
dwrestle
Crap I was hoping you would say low end torque for SD EFI. The cam was only $30 on Craigslist.
Old Feb 6, 2009 | 01:29 PM
Beechkid's Avatar
Beechkid
2500 to 5800 rpm is the operation band. While just a little high for a truck, advancing the cm about 3 degrees would bring the band down about 500 rpm and a .25 differential gear reduction would compensate for another 300 rpm making this truck a screamer!
Old Feb 6, 2009 | 02:33 PM
Conanski's Avatar
Conanski
No.. for that you want 195-205 duration @ 0.050" and LSA of 114 or more. Lift of up to 1/2" or a smidge more is no issue.
Old Feb 6, 2009 | 05:36 PM
Freaksh0w's Avatar
Freaksh0w
Yeah, power comes from lift, and the power band comes from the duration.
Don't nit pick it, I'm just saying in general.
There's a few tried and proven torque cams on here that work with the stock computer.
