'Idiot light/gauges'
Old Feb 6, 2009 | 01:05 AM
displacement4me's Avatar
displacement4me
I'm putting aftermarket oil pressure/water temp gauges in and was wondering if I can pick up the blank idiot gauges to fill in the factory gauges since I am using after market ones. and if it would be possible to put another type of display on the blank gauge?
Drill and stick a small Painless led indicator through it and then label it or paint it so it would be readable from the bulbs I already have there?
Old Feb 6, 2009 | 09:18 AM
Franklin2's Avatar
Franklin2
You cannot swap gauge clusters with idiot light clusters. The wiring for the charging is a little different.
Old Feb 6, 2009 | 10:37 PM
displacement4me
Ok thanks, how about for the automatic gear selector - a manual trans truck would've come with a blank? Can that be swapped in place since I'm going to a manual?
Old Feb 7, 2009 | 09:22 AM
Franklin2's Avatar
Franklin2
I am not sure on these trucks, but on other cars I have messed with, you just take the PRND21 piece out.
Old Feb 7, 2009 | 12:32 PM
desperado_18_2000's Avatar
desperado_18_2000
You certainly can un-bolt the prnd21 piece from the instruments and replace it with a blank piece. I've done this several times on my truck, as i 've swapped various clusters in/out.
Old Feb 7, 2009 | 01:09 PM
displacement4me
Ok so I can do the auto to manual blank, but not the oil pressure and water temp to blank?
Old Feb 7, 2009 | 05:46 PM
Franklin2's Avatar
Franklin2
You can take out the water temp and oil pressure gauges and blank them off on your original gauge cluster, you just can't use a factory idiot light cluster.
Old Feb 7, 2009 | 06:02 PM
displacement4me
Sorry but one more question then.
Can the blank be a piece of mild gauge aluminum or brushed sheet or something? Will that tie into the back somewhat nicely - and then that way I could paint it, as well as drill the indicator light I was thinking about.
