Charging Problem
Old Feb 5, 2009 | 08:25 PM
F250GH's Avatar
F250GH
Charging Problem
OK, on my second voltage regulator and still no charge at battery while at high idle. New Motorcraft alternator, new alternator harness, and second voltage regulator. Tested conductors of harness, all have continuity. From regulator plug on harness, the yellow and green wires plug into headlight harness which run back to dash cluster for alt light. The yellow female plug at the regulator is hanging with no capacitor attached. Seeing there is no radio, why would I need it? I also have NO fuses in the fuse block yet. I don't believe the charging circuit would run through it.
So there's my problem. I have a good ground at the alternator and voltage regulator. I strapped the 1st and 3rd position on the regulator plug at high idle and got 17 volts at the battery.
Old Feb 5, 2009 | 08:35 PM
camperspecial65's Avatar
camperspecial65
did you have the alternator checked...though new, they can be bad at times...been there a couple times before.
- cs65
Old Feb 5, 2009 | 08:58 PM
F250GH's Avatar
F250GH
Problem solved!
Purchased 3 Voltage Regulators, 1 Motorcraft and 2 Napa. Motorcraft and one of the Napa's are defective right out of the box, (No Charge). Last one works perfectly, 14 volts at idle.
hollywoodusmc
Apr 1, 2016 09:56 AM
fordtough81
Aug 1, 2015 10:55 PM
19-F250-78
Nov 12, 2012 01:59 PM
Sillbeer
Electrical Systems/Wiring
25
Dec 7, 2010 08:11 AM
alec001
Oct 10, 2003 05:24 PM
