53,54,55 and 56 Frames
Old Feb 5, 2009 | 04:46 PM
rnelson664's Avatar
rnelson664
Is the 56 F-100 Frame the same as the 53,54 and 55? I have a 56 body and 53 Frame and I was wondering if they will work together. Thanks much.
Ray
Old Feb 5, 2009 | 04:51 PM
eanderson56's Avatar
eanderson56
To my knowledge, the 53-56 frames are all identical.
Old Feb 5, 2009 | 05:29 PM
jaye's Avatar
jaye
The only difference I know of is the 56 running board brackets are different than the 53-55 however, everything should bolt up.
Old Feb 5, 2009 | 05:30 PM
CharlieLed's Avatar
CharlieLed
The frames are not identical, the rear leaf spring length differs but that does not keep you from mounting a 56 cab on a slant cab frame. And as Jaye has pointed out, the early frame has a spot on the drivers side running board bracket to mount the under-cab gas tank. If you are using the 56 gas tank that is in the cab or an aftermarket under-bed tank then this will not be a factor either.
Old Feb 5, 2009 | 05:41 PM
jaye's Avatar
jaye
As CharlieLed mentioned the rear springs are diferent on the 1955-56 they are 52” I think the 54-54 are 48".
Old Feb 5, 2009 | 05:54 PM
Fomoko1's Avatar
Fomoko1
I`ve set my 53 M350 cab on a 56 F100 frame, everything seems to line up ok.
rnelson664's Avatar
rnelson664
Thanks all. The gas tank will be relocated under the bed and I will go with a coilover springs in the rear so the frame should work just fine. Thanks again.
Ray
96XL
16
Dec 30, 2014 07:52 PM
Flat Ernie
WTB - Parts & other
Dec 13, 2014 03:41 PM
DGMFORD
WTB - Parts & other
Nov 20, 2014 10:49 AM
jaye
Nov 18, 2007 05:57 PM
bradoemba
Jul 14, 2005 12:50 PM
