I’m looking for the electric break controller wiring harness on my ‘99 E-350 super duty Van. I have found two plugs on the left side of the van behind the kick panel taped to the wiring. One plug is a single wire (red) the other is a five wire with three pins on one side and two pins in opposite corners on the other side. Are these the plugs I’m looking for?
Also I have four wires that run to the back bumper on the drivers side. The plug has been cut off and a four pin trailer connection spliced onto them. How do I hook them up for a 7 pin RV plug?
My break controller (Draw-Tite) has a display that shows a number that corresponds to the pressure being applied to the trailer breaks. When I step on the break peddle with out the trailer connected all I see is a decimal point. When I step on the break peddle with the trailer connected it shows a number that gets higher until it reaches its preset maximum. If the wiring is shorted out some where or not working then it shows a code the paper work that came with the controller explains the different codes. For instance when there is excessive moisture in my plug and I step on the break peddle with out the trailer connected the display reads 0.0
I'd like to install a Ford tow command brake controller in my '09 F250 super duty that has the factory tow pkg. I'm trying to find out if it will be neccassary to change the master cylinder??One mechanic said yes,another one said no,anyone know which mechanic I should use. Thanks,
(just realized I posted this on the wrong forum,sorry)
Reason: posted on wrong forum
