Tilt steering column loose
Old 02-05-2009, 08:29 AM
mds47588's Avatar
mds47588
mds47588 is offline
I had found a truck with a tilt column and the price is certainly right. But, it won't be any good to if it can't be fixed, right?
If the wheel is pulled even with the slightest amount of pressure towards the driver, it will "unlock" the column and the wheel will tilt to whichever direction it's being pulled to. Is this an easy fix? If so what would need to be replaced, tightened...etc? Or, would I simply be better off moving on to another donor?
Old 02-05-2009, 09:17 AM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,703 Likes on 1,377 Posts
People have a bad habit of pulling themselves up in the cab, especially on 4x4 trucks, and a lift or big tires makes it worse. The column has a big pot metal piece that holds it together, and that is famous for cracking when it's abused like that. I have never replaced it before, but a guy I work with had that problem and he got a Ford mechanic to do it for him on the side.
Anything to do with the steering column is a pain. I have worked on several, and it's always an aggravation. There is another pot metal piece that breaks all the time that goes to the ignition switch on the tilt columns(we just had a thread about that), so while you are in there, you could check that piece too. I had to go to the dealer and ask them how to get that piece back in place(it comes out easily when it's broken in 2 pieces) and they directed me to one of the shop guys and said "he is our steering column guy". What does that tell you?
ChristopherBarnette
07-16-2021 01:06 AM
Bigbruce
06-23-2013 08:35 AM
DaytonaTunnel
01-16-2011 11:12 AM
Danny_Ocean
06-19-2006 10:57 PM
Craigthebull
1978 - 1996 Big Bronco
03-18-2000 11:20 AM
Quick Reply: Tilt steering column loose
