Sponsored by: Real Truck
4.5" Lift Question
Old Feb 4, 2009 | 11:03 PM
Desert 4x4's Avatar
Desert 4x4
4.5" Lift Question
Guys I installed a 4.5" Icon lift on my 2004 F250 supercab shortbed 5.4. I went with the rear block, which Icon now uses flat blocks. I have a slight vibration at approx. 70-75mph and I am wondering what degree shim I should go with in the rear, or if should I install a 5" spring with the factory block. I would prefer to keep the factory spring.
Thanks for the help
Desert 4x4
Old Feb 5, 2009 | 07:41 AM
HeavyAssault's Avatar
HeavyAssault
IIRC the angled block was used for trucks with your configuration. I have the same lift on a CC LB using the 5" flat block with no vibes.
Have you talked to ICON?
Old Feb 5, 2009 | 07:51 AM
03_PSD's Avatar
03_PSD
do you have a two peice drive shaft or one? could be the carrier barring needs to be shimmed.
Old Feb 5, 2009 | 08:03 AM
BADAS03SVT's Avatar
BADAS03SVT
I thought the carrier only involved slow speed? I could be wrong..I did the Icon 4.5" and had a small vide off idle up to about 10mph and added the carrier shims and its gone.
and in the back (blocks) I opted for 1" more than what came with the kit and my truck has been ok?? not sure if my block was angled or whatnot
Old Feb 5, 2009 | 01:33 PM
DCSpecial's Avatar
DCSpecial
Shim the carrier too much and you get high speed vibes.
That's neither here nor there for the original poster as he has a one piece driveline....no carrier bearing.
Icon only makes flat blocks now since the majority of trucks lifted have two piece rear drivelines.
With a 4.5" the 5" flats normally work fine...you may need a 2* shim.
5* tapered blocks may be too much for that height.
Old Feb 6, 2009 | 12:34 AM
Desert 4x4's Avatar
Desert 4x4
Thanks for the help guys. DC is right with the SC/SB I have a one piece drive shaft. DC where would I look to get a 2* shim?
Desert 4x4
