Tranny?
Old Feb 5, 2009 | 08:21 AM
fortric's Avatar
fortric
thanks for the offer. I am in Bremerton, a little far for you. I ordered up a programmer. Been wanting one and I can use it to get the codes.
Old Feb 5, 2009 | 09:39 AM
Powerstrokedlariat's Avatar
Powerstrokedlariat
It will serve you well to have it on hand, even if it is once in a great while. No problem on the offer, you'll find most of us here will bend over backwards for another member.
Good luck and keep us posted with the outcome, and hopefully we can get you going again quick!
Old Feb 5, 2009 | 10:38 AM
SkySkiJason's Avatar
SkySkiJason
FWIW, I've had UVC (under valve cover) harness issues. The plug would get loose and no GP's and injector issues while loose - but truck would start right up, just had a baaaad miss. Its kinda cold where you are right now, so that could make a difference. It may sound silly, but are batteries GOOD. The engine can easily turn over - but if less than 10.5 volts to computer, no start. Could even cause weird problems while driving... Engine oil level OK? These trucks won't run w/o oil.
Old Feb 5, 2009 | 11:25 AM
fortric's Avatar
fortric
I have been able to get the engine to start. it runs rough. the batteries are new and oil level is good. The UVC harness it the frist thing I'm gona check tomorrow when I finally have some time to work on it.
Old Feb 7, 2009 | 09:00 PM
fortric's Avatar
fortric
I replaced the fuel filter because it needed it and didn't help. after getting truck towed It started right up but was running very rough. I tried to move the truck to my garage and it didn't have enough power to move and it stopped running when I tried.now it wont start again.it turns over strong and tries to start but just stumbles. Tach shows some rpm when turning over.dont get a check engine light or service engine light. i have checked the under valve cover harnesses and they look good and weren't loose. i havn't been able to find a scan tool that will work. mt programmer will be hear monday and then I'll be able to see if there are any codes. so any more Ideas? This is my first diesel so I am kinda lost on what to try next. when it was running and when trying to start it putting out a good bit of grayish white smoke.
Old Feb 7, 2009 | 10:15 PM
DieselCamper01's Avatar
DieselCamper01
Here is a bump. This is past my knowledge unfortunately.
Old Feb 8, 2009 | 07:21 PM
SkySkiJason
Well, it should run, even if fuel pump was bad - so its prolly not that. Open bowl drain and turn key on, if fuel comes gushing out, the pump works.
I had weird issues including no-start after doing the 10k mod the first time. Moisture got in ICP plug and caused a mild short. I guess you could look in there if you've washed engine recently.
Just throwing what little I know at ya while giving you a bump! Keep us posted.
Old Feb 8, 2009 | 07:31 PM
Kwikkordead's Avatar
Kwikkordead
I'm in N. Seattle with a Diablo Predator that will read codes.
I don't keep it at work so you'll have to call ahead if you need me to scan your truck.
Info is in my profile.
Old Feb 8, 2009 | 08:52 PM
fortric's Avatar
fortric
I'll have a preditor here tomorrow.
Old Feb 9, 2009 | 09:18 AM
Kwikkordead
You'll like it. The diagnostic section is pretty good, IMO.
It enabled me to find a bad injector very easily.
