One of "Those" days
One of "Those" days
Been battling bad glow plug system all winter, it doesnt help that we have had almost 10*f or lower almost everyday. Ive already chewed through a starter. replaced that, went to go start it this morning and the whole things frozen, fuels geled. charging system is worthless, its 4* today. I have 7 zd-11 glow plugs (penny glow plugs) but i have no idea how to tear into it. how much can i expect to pay a shop to do this? I figure the gpr will be anywhere from $30to60. and i have the glowplugs (minus 1). I have removed my turbo numerous times and changed out for the wicked wheel, also did my enitre exhaust. how tough is it? could i do it myself? thanks for the help, trying to make it to class and pay the bills, neither is happening today
Driver's side is easy, passenger's side is not so easy b/c of all the stuff you have to remove. Get yourself a piece of tubing that will fit over the end of the glowplug. What you'll do is break it loose with a 1/4" drive deep 10mm socket, and then put the tube on the end to spin it and pull out. Otherwise it gets tight with the socket in place to get it out. If you've pulled your turbo then this will be super easy for you! Torque down the rocker bolts too while you're in there!
I found the torque values for you:
GPs - 14ft-lbs<BR>
Rocker arm bolts - 20ft-lbs(just check them).<BR>
Lower injector hold down bolt to 120 in-lbs (NOT FT-LBS!!!)
Double check wires to make sure they won't contact valvetrain.
Can't you plug her in to help her get warm & fired up? You're probably not running synthetic and if you switch over to it, you'll notice a HUGE difference. I did. It's worth it.
GPs - 14ft-lbs<BR>
GPs - 14ft-lbs
GPs - 14ft-lbs
Changing a glow plug is about as hard as changing a spark plug. It's just getting all the stuff out of the way so you can reach the glow plugs. https://www.ford-trucks.com/forums/8...overs-off.html
