1978 - 1996 Big Bronco
big problems???
Old Feb 3, 2009 | 07:01 PM
mikeismadness's Avatar
mikeismadness
big problems???
i have an 1983 Ford Bronco. 302 sb. holley 2 barrel carb. i will run perfect when it starts up in the morning but as soon as the engine warms up it will run crappy. misfiring horibly. i cant seem to figure it out. put new plug wires istributor cap an rotor. the radiator has a hole in it and i ran it low on coolant for a few days but it never overheated. just checked plugs there fine. anyone have any ideas? i need help b/c this is a daiy driver and it sucks trying to go places when there is snow covered streets and i have no power to go up hills. oh and i havea really bad carb backfire. the carb is basically new.
Old Feb 3, 2009 | 08:08 PM
Red Ford Truck's Avatar
Red Ford Truck
Well let me see.
I might need a little more info.
But here's a few suggestions. You may have a bad coil or a bad wire connection.
Also is there oil in the coolant or is there coolant in the oil from say a cracked head or a blown head gasket.
What colour is the exhaust and does it smell sweet?
I would suggest a check of all your grounds and ignition wiring connections.
If none of this works you may have to do a leak down test on the engine to find the problem.
GL, Rick.
Old Feb 7, 2009 | 11:52 AM
BroncoGuy4741's Avatar
BroncoGuy4741
Have you thought about rebuilding the Holly Carb. I had problems with mine running and it was the Carb. needing a rebuild. I feel it was a because of Ethanol being added to my gas.
Old Feb 9, 2009 | 09:00 PM
den7bronco1's Avatar
den7bronco1
are you sure you put the plug wires on right and set the timing right.
