Rear Suspension for a 54
Old 02-03-2009, 02:09 PM
daves54's Avatar
daves54
daves54 is offline
Finally got the front squared away and am looking for ideas for the rear. All of the stock stuff is gone except for the mounts for the leafs. I have seen what is out there but really don't have a preference one over the other. What is the best way to go?
Old 02-03-2009, 02:37 PM
jaye's Avatar
jaye
jaye is offline
In my opinion the best way is IRS it depends on you cash flow. I had springs & hangers from a Ranger on my 55 however, I currently have TCI's lowered leaf spring kit which I like. Check the tech articles for rear suspensions there are a few guys who have used T-Bird IRS & Jags. The TCI kit was really simple & easy that's why I went with it. There are also mono leafs that will fit the original brackets unless yours are trashed. Look below and check Rokcrln's "LFT's T-Bird IRS install lots of good pictures & Info.
Old 02-03-2009, 02:47 PM
low54's Avatar
low54
low54 is offline
Lots of different applications. 3 link, four link, depends if your going to want to haul stuff, or get a cool ride heigth....personally I went with what I could afford, I raised the front hangers to the top of the frame rail gives about 1 3/4 drop, then bought some extended Y hangers which gives about 2 1/2 inch drop...good luck!!
Old 02-03-2009, 02:58 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
I have TCI 4-bar with coilovers and love it. Easy to install, can adjust the ride height, and can adjust the stiffness of the ride.
Old 02-03-2009, 05:19 PM
daves54's Avatar
daves54
daves54 is offline
I was looking at a corvette set up. Looks good in the picture anyone seen one up close. I have a mpoar front end I may as well make a real mutt!
