Before/After Pics needed
Old Feb 3, 2009 | 01:29 PM
ggwash21's Avatar
ggwash21
I'm looking for Before/After pictures of stock F150 and then adding the 3" spacers and rear blocks. I found the kit with the 3" spacers up front and the blocks in the back. Now my question is even with the rear blocks will this take care of the front sag?
Old Feb 3, 2009 | 07:26 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
4x4:
the 3" up front will make you nose high with nothing else
the 3" block out back will make you sit level, or very slightly butt high
4x2:
the 3" up front will make you about leveled out with nothing else
the 3" block out back will put the factory rake back on
I can give you before/after pics of my 2.5" kit...but my 3" rear is still sitting on my garage floor. I can't seem to find time to install it.
Old Feb 3, 2009 | 07:34 PM
DaMole's Avatar
DaMole
This is a 2.5" kit with the rear block.
Before
After
All the other pictures in my gallery are with the kit also. I will try to find a better after picture. My truck now sits with a slight rake. You should pretty much sit dead level with a 3" in the front and the replacement blocks in the rear I would think.
Old Feb 3, 2009 | 07:47 PM
nascar88ford's Avatar
nascar88ford
Before
After
Wow! That truck looks great!
Old Feb 3, 2009 | 10:25 PM
ggwash21's Avatar
ggwash21
I like I like alot.... This kit is on ebay and has 3" front spacer and 1" block in back.
Ordering it in the morning i just wanted to see how big of difference it made.
Old Feb 4, 2009 | 11:25 PM
Desert 4x4's Avatar
Desert 4x4
so to level a 06 F150 2wd I would need the 2.5" kit?
thanks
Old Feb 5, 2009 | 12:54 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yes, a 2wd will sit almost level with a 2.5" kit.
4x2 are 1" shorter up front, and 2" lower out back than a 4x4
Old Feb 5, 2009 | 10:39 AM
ggwash21's Avatar
ggwash21
Tylus Let me see pics of just the 2.5" installed. i'm debating if I wanaa do the rear block or just add the 2.5 or 3" up front
thanks
Old Feb 5, 2009 | 01:15 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
On my iPhone right now...look in my gallery
I've got pics of it in there...I suggest you only do a 2" if your not doing the rear block.
A 2.5" makes most trucks sit either perfectly level (like me) or nose high. So I only suggest using the 2.5" or 3" in conjunction with a rear block or leaf
Old Feb 5, 2009 | 01:26 PM
ggwash21's Avatar
ggwash21
I can get the 2" for like $65 off ebay or i can get the 3" with rear block or leaf for $165. I can do either one i'm just trying to help my self decide which is best lol
Old Feb 5, 2009 | 05:13 PM
DaMole's Avatar
DaMole
My truck with just the 2.5" front made it sit slightly nose high. Like Tylus suggested if you don't want to do replacement blocks I would suggest just going with the 2". If I had to do it all over again I would do it the same way I did it.
Old Feb 5, 2009 | 06:03 PM
ggwash21's Avatar
ggwash21
i decided to go 3" blocks and the rear blocks
Old Feb 5, 2009 | 06:31 PM
DaMole's Avatar
DaMole
Good luck. Make sure to take lots of before and after pictures.
Old Feb 5, 2009 | 08:10 PM
ggwash21's Avatar
ggwash21
Will do. Now i have to let the wife let me order the wheels i want. been doing alot of cleaning and baking/cooking to butter up for them hahaa
Old Feb 5, 2009 | 09:37 PM
stanger_missle's Avatar
stanger_missle
Before
After
I just recieved the exact same kit in the mail today! How do you like the AS kit? I hate how raked the 4x4s are. I was hoping that my truck wouldn't look wierd with the 2.5" in front and the 1" in back with the stock 17" rims and stock tires. Now that I see pics of your truck, I think I'll be more than happy with the AS kit. Your truck looks awesome!
