2004 5.4 engine pinging
Old Feb 3, 2009 | 12:20 PM
RUSTANG67's Avatar
RUSTANG67
Engine has started pinging at light load. When we first bought the truck (new) it had the same problem after about 10k miles. The dealer installed special spark plugs (?) and that took care of the problem until recently (77k miles).
Is anyone familiar with the spark plug change? Or is this a reprogramming issue?
Old Feb 4, 2009 | 09:50 AM
jsoko's Avatar
jsoko
I would have thought it would have been an octane & timing issue. Do you know what type of SPECIAL plugs the dealer used?
Old Feb 4, 2009 | 11:29 AM
slc10844's Avatar
slc10844
Try cleaning the mass air flow sensor.
Old Feb 4, 2009 | 02:34 PM
Jim Allen's Avatar
Jim Allen
Are you running a programmer, or any other mods like an intake system? No check engine lite? If so, find out what that code is and follow the clues. It might be as simple as a load of wee-water gas. Try the easy things first.. fill up with a good name brand Top Tier gas, see what happens.
Old Feb 4, 2009 | 03:08 PM
motown's Avatar
motown
I second, with trying to clean the throttle body. If you are running a oiled air filter ( K & N ) and have recently cleaned and oiled it, this can cause the throttle body to become oil covered and cause pinging.
Old Feb 6, 2009 | 08:10 AM
RUSTANG67's Avatar
RUSTANG67
The truck's completely stock. No mods. (it's my wife's truck and she won't let me near it!)
I assume the mass airflow sensor's in the intake. How do you clean it? Compressed air? should it be removed from the truck to clean?
All good suggestions...
I might call the Ford dealer and see if they have record of the plugs used. Where would I find some sort of notification from Ford if this was a recall type deal?
Old Feb 6, 2009 | 09:07 AM
motown's Avatar
motown
All you have to do is take off the air Cleaner, its real easy to do. Get a couple of cans of Throttle body cleaner CRC, makes some. You do it with the Key off, or you could damage the stepper motor for the trottle. You open the butterfly and spray the inside of the intake and throttle body. Then start the vehicle after cleaning. It may not start easy, though.
Old Feb 6, 2009 | 09:09 PM
Djack04F150XL's Avatar
Djack04F150XL
Not familiar with the MAF problem but at 77K you may be getting carbon around the plugs. I changed mine at 72K and they were carboned up on the heatshield. The plug problem is only on the 5.4-3V.
Last edited by Djack04F150XL; Feb 6, 2009 at 09:12 PM. Reason: Did not see it was a 5.4
Old Feb 8, 2009 | 07:25 AM
jsoko's Avatar
jsoko
call the dealer and find out about those SPECIAL plugs, and let us know
twigsV10
Modular V10 (6.8l)
72
May 11, 2017 12:41 AM
RedBirdin96
May 5, 2017 10:35 PM
spreng37
Oct 25, 2014 02:28 PM
perryg114
Modular V10 (6.8l)
Oct 25, 2013 03:28 PM
opeterson
Mar 26, 2006 05:20 PM
