Crank Case Venting
Old Feb 3, 2009 | 02:16 AM
bkks744's Avatar
bkks744
Question Crank Case Venting
Ok guys I have searched and searched regarding the weeping problem and believe one of the main issues causing the weeping is the crank case pressure..... I seems like no matter how many times you get the leak fixed at the bell housing, it leaks just after bringing it home. Dealer explained it is because the factory CCV is not sufficient enough. Now I have learned how to reroute the CCV but my question is has anyone improved the CCV by doing a custom MOD of some sort.??????????
Old Feb 3, 2009 | 02:30 AM
duallyking's Avatar
duallyking
I think I saw a write up of doing a different crankcase venting in the how to sections for the 6.0. There should be a sticky above this post.
