Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
How much air pressure into a plasma cutter?
Old 02-02-2009, 07:43 PM
460's Avatar
460
460 is offline
The compressor at work has 175 PSI. Can I hook a Hypertherm Powermax 380 plasma cutter up to this 175 PSI without damaging anything inside of it?
Old 02-02-2009, 10:13 PM
Half Breed's Avatar
Half Breed
Half Breed is offline
It won't work as well if at all with out a Regulator, most Plasma cutters use an average of 30lbs of pressure and that varies at the thickness of the metal your cutting. Most Plasma cutters have a built in reg. and as long as that is working you'll be fine. Check for the desired pressure in the manual for the thickness your cutting.
Old 02-03-2009, 12:39 AM
460's Avatar
460
460 is offline
Yeah, it has a built in regulator that gets set at 60 PSI. I'm just hoping that 175 PSI isn't too much into the regulator.
Old 02-03-2009, 04:14 AM
Half Breed's Avatar
Half Breed
What does the reg. show as max press. If it doesn't show less than 175lbs.- 200lbs. you should be ok. If it shows less that the 175lb then you'lll have to put an external reg. on it or you blow the seals in the one on the plasma cutter. As stated above the amount of air you actually need going thru the Plasma cutter depends on the thickness of the metal your cutting.
Old 02-03-2009, 11:16 AM
460's Avatar
460
460 is offline
Alright, I drove to the shop to check it out... the regulator reads to 140 PSI, and there is a sticker on the back of the machine that reads 120 PSI max. It looks like I'm going to be buying a small regulator soon.
Old 02-03-2009, 06:42 PM
Half Breed's Avatar
Half Breed
Yep, you'll need a reg. that will handle 175lbs + 10% so a 200 psi reg. prior to the Plasma cutter will work fine. Once you have that in line, bring your line pressure to 20lbs below max on P/C then you will be able to control it with the reg. on the P/C.
Fordman96
Michigan Chapter
28
10-03-2016 09:13 PM
Ford_Johnston
02-24-2016 08:02 PM
rangernut09011980
09-27-2015 05:51 PM
johnfin1
17
06-11-2015 02:57 PM
Bikeitswift
Garage & Workshop
04-19-2004 01:09 AM
Quick Reply: How much air pressure into a plasma cutter?
