Coil getting hot and cracking
Old Feb 2, 2009 | 11:49 AM
Hunters's Avatar
Hunters
Looking for help with my coil problems on a 87 F150 with a 300 straight six. I have replaced the coil 2 times and each one has cracked. It appears to be getting too hot. Any ideas?
Thanks!
Old Feb 2, 2009 | 06:17 PM
tgore3's Avatar
tgore3
Check your charging system, see what the voltage is while the truck is running. If you check it with a multimeter at the battery it sould be around 12v off and 14-15v with engine running. might be voltage regualtor
Check voltage to coil with key in run position, should be 6-8v, might be ballast resistor
Sounds like the coil is getting too much voltage.
Old Feb 2, 2009 | 06:25 PM
MisterDave2's Avatar
MisterDave2
Ditto, vr is probably shot sending v high for periods of time.
Old Feb 3, 2009 | 09:32 AM
Hunters's Avatar
Hunters
Thanks guys....... will see if this gets me going again.
