Can I replace the piston rings from the bottom without taking off the heads? I have one cylinder with low compression. Not sure how these are made so that is why I said "stupid question". It is the #8 cylinder. looking in the cylinder with a scope cam it appears that the walls are good and the piston appears to be in good shape so I assume the rings have failed.
This is not an answer to your question but have you done a leak down test to check for a bad valve?
I would suspect valves leaking before I would suspect rings. You need to pressurize the cylinder with a adapter that screws in the GP hole. If you do need rings you have to pull the head.
I read a couple things about pulling engines and oil pans
Somewhere I read that if you have to pull the engine, it's actually easier to lift the cab up to work on the engine. I disremember where it was but I saw pics of it. Same was for the E-Series and I saw those pics also. 8 bolts to unhook the cab and 12 for the E.
Oil pan, I just saw where someone cut hid crossmember out, did his business and then welded it back it.
Not sure if I would do it that way but it is food for thought....
That was me that cut the cross member for the oil pan. I was skeptical too, but after talking to a few guys in the 99-03 forum they steered me to one guy that 7 years on a cut cross member w/o a failure. I wouldn't hesitate to do it again. Bet I can do it in less that 4 hours now that I have one under my belt.
The only way to do rings is with the engine out. Might as well rebuild the whole thing if you're going that far IMHO.
