95 5.0L starting issues. Please Help
Old Feb 1, 2009 | 09:16 PM
95yarddog's Avatar
95yarddog
Guys, i have a 96 5.0L 4x4 auto. It cranks, and i have power to the coil. I checked the ground and hot side of coil w/ a noid light and don't have a ground. It is not lighting up the light like it should. I also put a new ignition module on the truck and a new distributor and had same symptoms. I do have power to the coil, just now ground. Any help would be great!
Old Feb 1, 2009 | 09:32 PM
JRS2's Avatar
JRS2
Back to basics. Do you have fire at the plugs ? Do you have fuel pressure ? What do the plugs look like ?
Old Feb 1, 2009 | 09:37 PM
95yarddog's Avatar
95yarddog
there is no fire at plugs or coil i do have fuel pressure and the plugs are new i have also changed coils and ignition mod right now i am trying to trace ground wires. any other thoughts would be great
Old Feb 2, 2009 | 03:56 PM
95yarddog's Avatar
95yarddog
got the truck running, coil wire to the cap had a lot of resistance going through it so i swapped it out. starts and runs but idles rough. checking timing and its good and made sure plugs were right on. any suggestions?
