1 bad GP
Old Feb 1, 2009 | 06:39 PM
rmalottwtes30's Avatar
rmalottwtes30
1 bad GP
Will one bad GP make my truck harder than hell to start? I checked them all out by using a test light and the light came on all except for one of them. Ok maybe its my wiring since I did the solid state conversion. I pulled off all the wires from the GP's and used a test light on them by attaching it to a ground and they all worked because the test light came on. I wouldn't think one GP would do this, or would it?
Old Feb 1, 2009 | 08:15 PM
Ironman03R's Avatar
Ironman03R
Yes one bad (high resistance) one will not let the controler keep the GP's lit long enough. Use an OHM meter and check resistanse through the plug with the wire unhooked, a test light can light up on a high resistance plug. You want less than 2 ohms on a good plug.
Old Feb 1, 2009 | 09:41 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Actually the ideal resistance is between .5 and 1 ohm with the solid state system.
