Has anyone changed the blinker switch in the steering column? Blinkers will not work, 4-way flashers work. Not sure what else it could be. Please advise. Thanks for the help.
i changed the multi-function switch in the taurus, pretty much the same thing as in the ranger. it turns out though i really had a issue with the fuse block not having power in the right areas, had to put in a jumper to make it work, as a result the key has to be on for the 4-way blinkers to work. i had several electrical issues, and they werent common to the same fuse. it was a real hair-puller!
