Sponsored by: Real Truck
Drivetrain Vibration When Towing
Old Feb 1, 2009 | 01:19 PM
PSDx3's Avatar
PSDx3
I have two 2002 SD, PSD's that do the same thing. When towing a trailer which weighs around 8-10,000 lbs. there is a vibration when just starting out on an uphill pull. Only does it at low speed and on a incline. Does not do it when starting level. Both have air bags in the back to level the truck for the tongue weight. It is regular hitch pull not fifth wheel. If you give it more power it gets worse. You just have to ease through it until you gain some speed. Any ideas? I'm thinking driveline wind up or a change in the driveline/pinion angle, something like that. Just don't know what to do about it.
Old Feb 1, 2009 | 01:38 PM
high ho silver's Avatar
high ho silver
Long bed or crew cab? Could be center support bearing on driveshaft.
Old Feb 1, 2009 | 01:55 PM
caprang's Avatar
caprang
Check the end play of the driveshaft. I wouldnt think this would be a problem with the air bags but its still possible due to axle wrap.
Old Feb 1, 2009 | 02:16 PM
high ho silver
Watch this video. It may answer your question.
YouTube - Axle Wrap 2003 F250 4x4 no traction bars
Old Feb 1, 2009 | 03:19 PM
PSDx3's Avatar
PSDx3
One truck is longbed supercab, the other is a shortbed crewcab. So there is only two inches difference in wheelbase. Everything along the driveline has been checked out. Watched the video suggested by high ho silver; very interesting. Way more movement than I would have believed. That could be the issue.
