Code 51 ,1995 F 150
Old Feb 1, 2009 | 08:46 AM
roadrunner doug's Avatar
roadrunner doug
Code 51 ,1995 F 150
OK, I am stumped.I had the clock spring replaced,then it came up with the 51 code.Found out on here it is a Thermal Fuse in the blue box.Went to the junk yard today and got a different blue box,same thing.I realize its a used part,but the airbags were not deployed in the junker.Should I take the box apart and check the thermal fuse for continuity?????I"m confused.Any help apriciated.Thanks DOUG
Old Feb 1, 2009 | 10:44 AM
Conanski's Avatar
Conanski
51 - ECT sensor signal is greater than the Self-Test maximum of 4.6 volts.
That's the engine coolant temp sensor as far as I know.
