2wd to 4wd conversion kits
Old Jan 31, 2009 | 02:32 PM
j74250's Avatar
j74250
Is there someone in the aftermarket that makes a conversion kit to convert a 2wd to 4wd?? asking for a friend.
Old Jan 31, 2009 | 02:47 PM
hotrod91174's Avatar
hotrod91174
I do not know about the aftermarket, but I would think that you could use all junkyard parts, or a donor truck to get everything from. another idea could be to find a 4wd chassis and put your body & motor in it. either way you go its alot of work.
Old Jan 31, 2009 | 03:13 PM
jumbofordman's Avatar
jumbofordman
No, they don't. The easiest and cheapest method of switching from 2wd to 4wd is to sell the truck you have, and buy a 4wd.
Old Jan 31, 2009 | 05:18 PM
cipsmithers's Avatar
cipsmithers
I second the chassis swap. If you are looking to keep your engine/body, that is the way to go. The frames are totally different.
Old Jan 31, 2009 | 08:33 PM
Thunderjet4x4's Avatar
Thunderjet4x4
I have seen later model Dana 60's used with coils and half ton radius arms on 2wd frames-pics in here somewhere. Looked slick, but more than likely more fabrication than most could/want to do.
+1 on the chassis swap! Making holes, if needed for body mounts is much easier.
Old Feb 1, 2009 | 11:00 AM
73BlackBeauty's Avatar
73BlackBeauty
I was throwing around the idea of swapping from 2wd to 4wd in my 73 F100. It is definately possible. Way to much work for me to get into right now. I agree that the chassis swap is the easiest way to go about this.
Old Feb 1, 2009 | 11:25 AM
75F350's Avatar
75F350
Its really just minor fabrication. If you can handle an engine and trans swap, and you can tackle a cab swap, a 4wd conversion is not that difficult.
Using a divorced transfer case eliminates the need to change the transmission as a 2wd trans can be used. The next thing is mounting sme hangers and installing some shackles.
Using an 80's D60 is difficult to do with the given widths of the front of our frames. Using a radius arm means that a section of the cast differential and driver side spring perch must be cut, but it can be done. You must use a spring buckets from a 4wd too, but again, this can be pretty easy. With long radius arm kits available, this has become a very reasonable swap.
Dont get me wrong, the modofication os a bunch of work, but in reality, swapping bodies, engines, transmissions, electrical, etc, is not an easy task either.
In the case of the 4wd conversion, this will require some welding to box the frame, and the steering box will have to be replaced, but this is true whether or not a 4wd frame is used. The stock steering is simply inadequate, and should be changed anyway.
Other than the front crossmember the frames are suprisingly similar.
Old Feb 15, 2009 | 06:31 PM
'78F250's Avatar
'78F250
I just finished mine...I did a frame swap and it took me a whole day to finish with the help of a friend. The main reason was i didn't want to move the front crossmember on my '78 f-250. Wish i would've taken pic's but didn't think about it at the time, was in a hurry to finish in one day. This is my daily driver
Old Feb 16, 2009 | 01:40 AM
jumbofordman
I've done a cab swap essentially by myself using a lift (used 1 friend for about a total of an hour, mainly to lift the front clip on and off, and right when I dropped the new cab on the frame.) It's really not that hard, so if you really have a nice cab then I could see swapping a good cab onto a 4x4 chassis. Otherwise I stick with my original statement that the easiest and cheapest method is to sell the 2wd and buy a 4wd.
Old Feb 16, 2009 | 10:38 PM
RVDan's Avatar
RVDan
I've done a 2wd to 4wd conversion twice. both times I had a 2wd truck that I wanted the body from and a 4wd with shot body.
The frame shape and steering box location on the 2wd versions just make it really inconvenient to put a front axle under. It requires fabrication and some non oem parts.
If you're planning to run a custom suspension with a lot of lift anyway, its no big deal, but if you're planning to stay at a reasonable height, you're gonna have to do a lot of cutting of the 2wd crossmembers to make it all work.
So I dropped my 2wd body on top of the 4wd frame. Requires some inner fender trimming for steering box and shock tower clearance and of course the hole for the transfer case shifter.
flip67
13
Jul 6, 2021 01:07 PM
Lug Nut
Dec 20, 2015 06:57 PM
bdubs1127
50
Jun 27, 2015 07:22 PM
quincyj34
May 15, 2015 10:48 AM
mxer0022
53
Apr 25, 2015 12:39 PM
