Sponsored by: Real Truck
leaking tranny fluid
Old Jan 31, 2009 | 10:41 AM
avidbowhunter's Avatar
avidbowhunter
All... i have an 01 f250 psd. When i park it on any kind of pavement or concrete it "leaves it's spot" like an old harley, but it's tranny fluid. Is there anywhere that is suspect to look? I've checked all the bolts on the pan and they were all tight. It leaks for awhile and then when the fluid gets to a certain level, no more leaks, but the truck still shifts fine. I check the dipstick and it shows nothing! Any advice would be appreciated! Thanks,Jeff
Old Jan 31, 2009 | 11:33 AM
boxcar1974's Avatar
boxcar1974
Shows nothing? Do you mean there is not fluid on the dipstick?
Have you looked at any cooling lines running to the radiator. I always have a small intermittent leak where the line enters the radiator. For the dipstick not to read you have to have a substantial leak. Be careful.
Old Jan 31, 2009 | 12:10 PM
avidbowhunter
thanks for the reply. It's not leaking at the radiator. It's coming down somewhere around between the tranny and motor, i think. And i did mean nothing on the dipstick!!!
Old Jan 31, 2009 | 03:32 PM
flamedoutf250's Avatar
flamedoutf250
I think i have the same leak as you , can`t find it though, I know it`s not the drain pan or bolts. Mine leaks above all that , but I haven`t found the problem yet.
Old Jan 31, 2009 | 04:06 PM
avidbowhunter
Hey, tell you what.. if i find out what it is first, i'll tell you and i you find it first, tell me!! Just hope it's not too expensive to fix!!!
Old Jan 31, 2009 | 04:14 PM
spinella's Avatar
spinella
try taking the inspectionn cover off the front of the trans. it covers the torque converter. look up behind the converter and see if the front seal (pump seal)is leaking. if so then the tranny has to come out.
Old Jan 31, 2009 | 04:17 PM
avidbowhunter
Thanks for the advice. I'll look when this "global warming" ends. Just too cold to put my fingers against cold metal!!
scooterspal
Mar 19, 2012 09:26 AM
Jeff396
Mar 5, 2010 05:52 PM
jcstarr
Apr 30, 2007 10:10 AM
ultrartwing
Aug 31, 2006 04:47 PM
CHRISRA
Aug 23, 2006 07:45 AM
