Jack points
Old Jan 31, 2009 | 10:07 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
Jack points
Ok, maybe dumb, but I want to be sure I'm jacking her up & securing properly. I've always had my buddy's shop to use for this before and never had a truck this big.
Where do I put jack stands? And what is the best place for lifting? I have a 3-ton floor jack & a 6-ton bottle jack. Thanks guys!!
Old Jan 31, 2009 | 10:11 AM
megawatt00's Avatar
megawatt00
I usually lift it up by the pumpkins and put the jack stands under the axle tubes. Before I had my duallly I would support the whole truck this was to rotate the tires.
Old Jan 31, 2009 | 10:13 AM
papadelogan
The driver's side is really tight. I'll get a pic.
EDIT
Here's the front view:
Here's the rear view:
Old Jan 31, 2009 | 11:56 AM
clintbonnie's Avatar
clintbonnie
Brendan.. it that salt deposits under your truck? They use very little salt in the winter on the streets here in washington state, so my 99 PSD under carriage still looks new still or close to it.... But it looks like you maintain your oil pan really good...
Old Jan 31, 2009 | 12:12 PM
guzzle92's Avatar
guzzle92
Not salt, Magnesium Chloride. They use a lot of it here in Colorado. It is somewhat corrosive but not as bad as salt.
Old Jan 31, 2009 | 12:13 PM
megawatt00's Avatar
megawatt00
I have 1 set of jack stands that fit inbetween the spring pad and the axle u-joint. I have also used a set of shims under the spring pad to "grab" the bolts and used the jack stand unser that.
Old Jan 31, 2009 | 12:18 PM
mueckster's Avatar
mueckster
EDIT
I place the jack stands under the front axle between the the spring bottom U-bolt plate and the steering knuckle.
Old Jan 31, 2009 | 12:43 PM
DCSpecial's Avatar
DCSpecial
I do the same in the front.
Rears under the axle directly under the spring under the axle.
Like this:
scooterspal
26
Sep 18, 2018 07:50 PM
Lowedogg
Sep 30, 2013 10:01 AM
FLAcharlie
1983 - 2012 Ranger & B-Series
Jun 5, 2006 03:06 PM
tombob
1978 - 1996 Big Bronco
Aug 28, 2005 12:08 AM
dalfollo
Garage & Workshop
Apr 11, 2004 09:42 PM
