Last night after a lousy day at work my wife called and informed that someone smashed in the passenger side window for the rear passengers. *******S! Well needless to say with weather being around the teens at night and the bag trick not working the glass needs to be repaired. I want to clean out the track the glass sits in. Does anyone know how to take the interior panel off? Are there any how to's or maybe pictures or tricks. Any help would be greatful!
I'm not sure about the 03 however on my 99 there's a small cover plate on the door handle that's removed to revieal the bolt to remove the handle, once this is pulled there's two screws on the bottom edge of the door pannel to remove, then grabing the pannel lift up then out. There again your 03 might be different but it's worth a shot.
