Differential maintenance
Old Jan 30, 2009 | 03:07 PM
desert sled's Avatar
desert sled
I am about to service the differential on my F-350. The ID tag says that it has a C5 differential,therefore it is a limited slip. The manual says to use 75/140 synthetic oil. Do I need to use a friction modifier if I use this synthetic? also i heard of a guy burning up his rear end after using the synthetic. Please help.
Old Jan 30, 2009 | 05:40 PM
Dave Sponaugle's Avatar
Dave Sponaugle
I run synthetic, no problems.
I also have limited slip and I do run the friction modifier.
Old Jan 30, 2009 | 07:31 PM
desert sled
Thanks for the response Dave,I will use both.
Old Feb 1, 2009 | 05:13 PM
ford trans tech's Avatar
ford trans tech
genuine motorcraft syn. gear lube does not require the limited slip additive
i would add it to all others
the rear end wouldnt burn up without it it would just have a chatter on turns
Old Feb 1, 2009 | 06:03 PM
Dave Sponaugle
Some of the other synthetics also do not need the friction modifier, but I can't say which does and which does not.
