Gauge wiring
Old Jan 29, 2009 | 09:14 PM
bmxstreet15's Avatar
bmxstreet15
Gauge wiring
Ok so I am hoping that someone with experience can help me out. I am getting ready to install boost, egt, and trans temp gauges. My question is, where can I draw power for my egt and trans temp gauge? I am guessing a hot on ignition but where can I get the power? Also, which wire do I tap into so that the gauges' lights work with my facory gauge lights?
Old Jan 29, 2009 | 09:21 PM
live2wheel's Avatar
live2wheel
on the fuse pannel there is an empty fuse slot for the air bag. its only hot when the key is on . i pushed a blade connector in there and used an in line fuse. for the gage lights, i spliced in the wire for the light in the ash tray . i thought that was the easiest spot.
Old Jan 29, 2009 | 10:10 PM
Gobstopper909's Avatar
Gobstopper909
you can put your lights on the dimmer with out splicing anything!! fuse #10 i believe. its the only 4a fuse in there
Old Jan 30, 2009 | 06:07 AM
Neal 97 250's Avatar
Neal 97 250
X2 I just tapped into the fuse in the panel. I believe it is #10 also not sure.
Old Jan 30, 2009 | 09:34 AM
ono_55's Avatar
ono_55
To power your gauges (EGT Trans) use #17 fuse in the cab for the lights use #10 fuse.
Old Jan 30, 2009 | 10:58 AM
bmxstreet15
Ok, Thanks everyone. You saved me alot of time poking around with the multimeter. Should have them in by monday. I am waiting on my pod to show up.
