Torque Converter?
Old Jan 29, 2009 | 07:09 PM
Mick1960's Avatar
Mick1960
Torque Converter?
I am having problems with my '82 F250. I just changed to fluid and now it is dark. It worked sluggishly for a while in the drive gears. then all of a sudden the drive gears worked sporatically. No problems in reverse. It will sometimes drive in the drive gear or L1 or L2. It will have power then nothing. Reverse is very strong. I am guessing that the torque converter is bad. When I changed to fluid there was very little sludge in the pan. Any ideas?
Old Jan 30, 2009 | 08:15 AM
Freightrain's Avatar
Freightrain
I'd say the TC is fine, if it goes in reverse fine. If the TC wasn't working, then you wouldn't get enough pump pressure to move the truck, or if it was a lock up it would slip.
I'd say there is a problem with the valve body. It controls the bands to make it go into gears. If the fluid is dark, then likely the clutches are burnt up and making it difficult to go Forward?
