brake problems
Old Jan 29, 2009 | 04:34 PM
73fordman's Avatar
73fordman
brake problems
does anyone know how hard it is supposed to be to push the piston in on the back of the master cylinder cause i barrely push it in with my finger and it compresses is that suppoesd to happen?
Old Jan 29, 2009 | 06:35 PM
garypettengill's Avatar
garypettengill
If you have your master cylinder in a bench vise and you are trying to bleed it prior to installation on your truck and you can push the piston in with your finger then you are one pretty strong dude. There is a fairly hefty spring on the other end of the piston that returns the piston when you take your foot off of the brake pedal. Normally I use a phillips screwdriver and then lean into it to bench bleed a new MC.
Old Jan 29, 2009 | 08:38 PM
Bgasrickshaw's Avatar
Bgasrickshaw
Is this dry or with fluid in it? You should have to push pretty hard to make it stroke 3/4 " to 1" when you are bench bleeding it until all the air is out and then you shouldn't be able to push it more than 1/8" If it is dry it's a lot easier to push, but you shouldn't really do it when it's dry anyway. Hard on the seals.
Old Jan 30, 2009 | 12:51 AM
73fordman's Avatar
73fordman
yea
its the one i took off my truck i think its the problem
