Heating Problems
Old Jan 29, 2009 | 01:19 PM
73BlackBeauty's Avatar
73BlackBeauty
Heating Problems
I have a 1978 F-250 and there is an issue with the heat. When I turn on the heat it blows warm air yet there is a fog that comes through the a/c vents that smells like antifreeze. Is the heater core bad or is it something else. Any one else have this problem.
Old Jan 29, 2009 | 01:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The heater core is leaking.
The passenger side floorboard/floor may also be damp if the leak has been occuring for several months.
Old Jan 29, 2009 | 01:30 PM
73BlackBeauty
It has been happening for a while now but It doesnt seem to be leaking. Ive had one leak before on a 73 F-100 and it was quite wet. I cant seem to find where this one is leaking. Any other options or is it definately the heater core.
Old Jan 29, 2009 | 01:38 PM
zak8tac's Avatar
zak8tac
Its 100% definitely the heater core. Nothing else it could be.
Old Jan 29, 2009 | 01:55 PM
NumberDummy
Originally Posted by zak8tac
its 100% definitely the heater core. Nothing else it could be.
D-i-t-t-o!
Anti-Freeze is leaking into the heater plenum chamber where the outside air passes thru after first passing thru the heater core on its way to the vents or defroster ducts.
The air picks up moisture from the Anti-Freeze, deposits it on your windshield as fog.
