Sponsored by: Real Truck
what is wrong
Old Jan 28, 2009 | 04:19 PM
looks's Avatar
looks
what is wrong
i was driving my F250 v-10 about 70 mph when it sound like i got a flat (loud slapping sound) no flat!!!!when i got pulled over and try to start my truck it is like it is frozee up any idea what it could be
Old Jan 28, 2009 | 04:33 PM
WeWonIt's Avatar
WeWonIt
Need more info! Will it turn over? What did the RPMs do during the incident? Did it die on its own or did you turn it off? Was it still making the sound at idle before it shut off? Ect....
Old Jan 28, 2009 | 04:55 PM
looks's Avatar
looks
It will not turn over at all. Not shur what the rpm did.It died on its own. I was under way when it shut off
Old Jan 28, 2009 | 05:06 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Check the engine - any holes in the block?
Old Jan 28, 2009 | 05:09 PM
looks's Avatar
looks
No holes. Has all fluids
Old Jan 28, 2009 | 05:18 PM
Mustang6147's Avatar
Mustang6147
Do you hear your starter engaging?? Sounds like you broke a rod. I am surrprised you didnt ventilate the block.
If you can get a breaker bar on the crankshaft bolt try to turn the engine, If not forward try back. If it mmoves back, when going forword again see if it feels like a sudden stop, as apposed to a bind.
Old Jan 28, 2009 | 05:21 PM
looks's Avatar
looks
ok thanks!!!!!!!
Old Jan 28, 2009 | 06:22 PM
WeWonIt's Avatar
WeWonIt
This does sound pretty bad. Let us know what you find when you try to turn the crankshaft.
Old Jan 28, 2009 | 06:30 PM
Fordfanatic4life's Avatar
Fordfanatic4life
yea u def. sound like u blew the engine in a major way...
cant think of what else would cause sucha loud noise and then not allow the engine to turn over...
hopefully for you its not, but dont be surprized if it is...
Old Jan 28, 2009 | 06:42 PM
Mustang6147
Somebody dropped a couple of nuts down my sons carb on his 289. His symptoms resemble yours. The nuts made it in to the cylinder. The engine ran but made a weird sound he said. Then wouldnt turn over with the starter. I found the bolts as I pulled the top end off. They wouldnt let the piston go all the way up. While the engine was running they beat the heck out of the chamber in the head.
Maybe you sucked a valve, ???? Trying to give you other possibilities
Old Jan 28, 2009 | 06:56 PM
Beerstalker's Avatar
Beerstalker
Do you have power for anything else (is the electrical system still working)?
Old Jan 28, 2009 | 07:50 PM
looks's Avatar
looks
ya it all works
Old Jan 28, 2009 | 07:56 PM
looks's Avatar
looks
would a timing chain do any thing that would sound like that .d Did not get to look at it yet. I will let u all know what i come up with.Thank u all for the ideas
Old Jan 28, 2009 | 08:30 PM
Mustang6147
If the chain comes loose or skips teeth, then valves would be kissing pistons
Old Jan 28, 2009 | 08:52 PM
rollerstud98's Avatar
rollerstud98
So the modulars are interference motors?
