05 with p0300 code
Old Jan 28, 2009 | 02:09 PM
amd916002000's Avatar
amd916002000
05 with p0300 code
i have a 05 f-150 with the 4.6l. i got a check eng light and it was kinda hard to start and cranks long before statting. after startting it runs good and starts fine untill it sits for a little while. i changed the plugs reset the computer. light came back on got the p0308 code changed the #8 coil reset the computer again..the light came back on again got the p0308 and p0300 codes thinking it might be something fuel i changed the fuel filter and and put a good fuel system cleaner in.. still hard to start i was on my way to get a fuel injector for #8, on the way the light came on again now im getting p0300, p0308, and p0306. im getting a little lost on this one and could use some help please...
Old Jan 28, 2009 | 02:47 PM
ALLDATAdiy INFO's Avatar
ALLDATAdiy INFO
Former Vendor
Could likely be a bad CMP (Camshaft position Sensor)
How much gas is in the tank?
Also can be an EGR problem.
Check the link in my Signature to ALLDATAdiy.com for complete OE testing.
Old Jan 29, 2009 | 08:04 AM
No-Tyme's Avatar
No-Tyme
Originally Posted by amd916002000
i have a 05 f-150 with the 4.6l. i got a check eng light p0308 code changed the #8 coil reset the computer again..the light came back on again got the p0308 and p0300 codes...
I was plagued with the P0308 code and a P0316 code for a long time. I am not sure if the codes you are receiving from your engine are the same dynastic info for my 04 5.4 3v, but if it is the P0308 is a misfire in #8 cylinder. If you swapped out the cop and still receive the P0308 then you’re still getting a misfire in #8, I would be concerned about the injector. The P0300 seems to point towards fuel delivery and since the injector is not that hard to change that would be my next step. The injectors are known to plug up: I believe that the 4.6 are the Romeo engines which I also believe have some issues with injector…
You wrench heads can chime in any time here!!!
ItsAndy
Mar 18, 2016 04:26 PM
Stevenmed
2004 - 2008 F150
Mar 11, 2016 10:28 AM
Roddy's Dad
Jan 9, 2015 07:37 AM
gassplant
2004 - 2008 F150
Jan 25, 2014 01:01 PM
5.4Triton
1997 - 2003 F150
15
Mar 30, 2012 07:36 PM
