starting trouble
Old Jan 28, 2009 | 09:02 AM
john12345's Avatar
john12345
starting trouble
i have a 1985 f-150 4x4 with a 351 motor. the truck doesn't always start with the key. some times i have to cross the selinoid. i replaced the selinoid, the starter, the ignition modgual, and the ignition switch on the colmn. does anyone know what else i can try? (the truck always starts when i cross the selinoid).
thanks, John
Old Jan 28, 2009 | 09:20 AM
Franklin2's Avatar
Franklin2
I would check the neutral safety switch. If you have a automatic, it will be on the driver's side of the tranny. If you have a manual, it will be mounted with the clutch pedal under the dash.
Old Jan 29, 2009 | 06:23 AM
john12345's Avatar
john12345
starting trouble
thanks dave, i will look at the nuetral safety switch. can i unplug the nuetral safety switch and eliminate it?
thanks, John
