4 to 5 speed
Old Jan 28, 2009 | 07:38 AM
desoto dave's Avatar
desoto dave
4 to 5 speed
i was reading a tread on putting a clark 285v in a truck to replace the 4 speed.you have to use a FT bell.Well i was under the impression that the fifth gear would help on the highway on the RPM's.the 5th gear is 1 to 1 ratio,i was talking to a fella that said the four speed is also 1 to 1.is that correct? if so it would'nt change anything wright? I have a 68 F350 with a tool body on the back ,i'm using it as a main work truck for my buisness.i'm currently rebuiding a Z code 390 out of a 66 t-bird 4 barrel.everything will be stock of the engine exept the cam,and the heads witch are d2teaa heads,that i ginded down the hump in the exaust and polished .and then some headers and a 600 cfm holley.i would like to cruise about 70 on the highway,and still have a tough drivetrain,it will always have a good amount of weight on it.and i would like to thank you all for all the great knollege on here it helped out tremendesly.
Old Jan 28, 2009 | 12:49 PM
jowilker's Avatar
jowilker
Dave, a 1 to 1 high gear ratio is 1 to 1 if it is a 2 spd or 9 spd. tranny.
You have to go to overdrive where the tranny tail shaft turns faster than the engine.
John
Old Jan 28, 2009 | 01:17 PM
desoto dave
i relize that , i'm just asking is the 4 speed that comes in the 68 f350 a 1 to 1 ratio?i'm just trying to confirm what the man said.i beleive there was two different 4 speeds for that truck if yall need a # i'll find it and post it.
Old Jan 28, 2009 | 01:23 PM
Madathlon's Avatar
Madathlon
In a 68, a 4 speed was reall a 3 with a granny 1st and 4th is 1 to 1
Old Jan 28, 2009 | 01:26 PM
desoto dave
tanx yall i guess i find a tranny with overdrive.
Old Jan 28, 2009 | 01:47 PM
85e150's Avatar
85e150
Four speeds were direct 4th for your year.
Another way to go here is the NV4500. Not cheap or free, not priced at scrap metal rates like a Clark from a burned out wreck.
This site had the conversion info, parts and the trans if you want, but you can probably get a trans elsewhere. With what you are doing already, this might could be childs play for you:
High Impact - NV4500 5spd
The NV4500 is a strong box with a low first and OD 5th.
That site also has an OD unit.
With an FE, you are limited due to the fact all the late model Ford issued transmissions have an integral bell which is for a different engine series.
More trans info:
Domestic Truck Tranny Guide
High $ OD:
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
Old Jan 28, 2009 | 06:52 PM
jowilker's Avatar
jowilker
You know something is kicking up some dust that there is a Clark Overdrive truck tranny, but I am not for sure. Maybe someone else will know.
John
Old Jan 28, 2009 | 10:57 PM
85e150's Avatar
85e150
There are Clark OD transmissions. Google "clark transmissons" and see what you find.
Old Jan 29, 2009 | 12:35 AM
Fritolay's Avatar
Fritolay
there are two easy ways to go both require some cash however. you could use a gearvendors unit which is basiclly a gear splitter that gives a 27% (??) overdrive. The other easy way is an nv4500 conversion. if you email the guys at high impact transmission they will get back with you pretty quickly and let you know exactly what you need to do the conversion. The thing to remember with the gearvendors unit is you can use it between every gear. I dont know how you load down your work truck or if you climb many hills but i know there are lots of times when one gear is way to short and the gear under is way to tall.
Old Jan 29, 2009 | 07:28 AM
desoto dave
from what i read the clark od and the nv4500 are about the same ratios on the gears, and supposabley they kind of rob some performance.i still wana have a little fun somtimes.i will look into all the options yall gave me thank you.i kind of like finding stuff in the junk yard and stuff like that to make it work instead of buying expensive upgrades,but somtimes ya have to pay for what you want.
Old Jan 29, 2009 | 09:10 AM
rbaker6336's Avatar
rbaker6336
Originally Posted by desoto dave
from what i read the clark od and the nv4500 are about the same ratios on the gears, and supposabley they kind of rob some performance..
ODs do rob some performance,that's why you see most OR trucks run direct drive trans and a taller rear ratio
6.whoa
Nov 16, 2016 03:47 PM
Brandy4ever
Aug 13, 2016 10:03 PM
tlrtucker
Jan 6, 2016 06:27 AM
roundman 50
16
Dec 20, 2010 09:06 AM
1finepilot
Apr 26, 2002 11:07 AM
