Fuel intrusion help.
Old Jan 27, 2009 | 06:18 PM
frenchslandscape's Avatar
frenchslandscape
I have a 92 7.3 and Its hard starting when the truck is cold. It cranks and cranks and cranks. When i get it started in runs pretty good. But when my foot is on the gas the fuel guage drops drastically and when i take it off it goes back to normal. So for what i have been reading on here it sounds like i have air getting into the system. The truck has a new fuel filter and new gp's. Where do i start looking for air getting in? thanks again guys.
Old Jan 27, 2009 | 06:53 PM
Franklin2's Avatar
Franklin2
If it had air in the system, it should start, and then die. The fuel will stay at the injector, but leak back behind the injection pump if it was getting air. So it will run for a few seconds, and then crank and crank.
Old Jan 27, 2009 | 07:48 PM
PLC7.3's Avatar
PLC7.3
How long does the WTS light stay on.........
How old are the injector return lines and caps.... are they grey.
How high are the RPMs of the fast idle set, do you press the fuel pedal half way down and hold it there for a start.......
What condition are the batteries...... what CCA are they and how old.
How fast does the engine crank over it must be faster than you can count.
Old Jan 27, 2009 | 11:35 PM
rupejosh's Avatar
rupejosh
do you have a capped off valve on the fuel filter head?not the schraeder valve but right next to it toward the front of the motor.
