full hydraulic steering
Old Jan 26, 2009 | 06:44 PM
StealthWyvern's Avatar
StealthWyvern
Anyone install full hydraulic steering on their trucks? You know the stuff that the rock crawlers put on their rigs.
I figure a few hundred bucks and you can get rid of the sloppy *** steering that these trucks are known for and a quicker responce of the wheel.
Old Jan 26, 2009 | 10:07 PM
atillett's Avatar
atillett
I was wanting to do hydraulic assist and was told that it is illegal to run hydro on the street...
Old Jan 26, 2009 | 10:33 PM
StealthWyvern
I don't see how it would be illegal at all.
Old Jan 26, 2009 | 10:54 PM
atillett's Avatar
atillett
I did not see the "law" but what he said made some sense and i lost interest. He said that if you are going down the highway and a piece of trash or debris came up and severed a line then there would be no steering to control the truck. IDK made sense at the time.......
Old Jan 26, 2009 | 11:49 PM
StealthWyvern
ah ok that makes sense but the same can be said about brake lines on how they run down the frame rail ect ect.
Anywho did you do anything about the stock stering setup?
Old Jan 27, 2009 | 01:02 AM
pfogle's Avatar
pfogle
Most modern brake systems are ABS or split reservoir system. They will still maintain some braking power with a loss of fluid.
Old Jan 27, 2009 | 01:21 AM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
I just put in a new steering box, made my steering a lot better.
Old Jan 27, 2009 | 01:58 AM
StealthWyvern
Your right. I didnt mean to imply that the brake system would fail completly just saying it can happen and has happened to me.
So your box was just wore out?
Old Jan 27, 2009 | 02:32 AM
DJdemon6696's Avatar
DJdemon6696
want a tight responsive steering
change all tie rod ends and rebuilt steering box..
ohh and rebuild pump also
Old Jan 27, 2009 | 04:29 AM
StealthWyvern
in short rebuild the entire steering setup. lol
Old Jan 27, 2009 | 05:10 AM
DJdemon6696
lol exactly
Old Jan 27, 2009 | 04:25 PM
1994 F250: 351, C6
I replaced my tie rod ends and my steering got better, put a new steering box right before christmas and it steers like a new truck. Its also cheaper and easier than a hydro setup.
Old Jan 27, 2009 | 04:42 PM
StealthWyvern
Then I wil do just that! I was always under the adumption that these trucks had that play in it but I guess I was just misinformed.
Old Jan 27, 2009 | 04:50 PM
1994 F250: 351, C6
There will always be a little play, this is not a rack and pinion set-up after all, but with a nice new set of tie-rod ends and a good rebuilt box there will only be a fraction of the play produced by worn out steering components.
I got my tie rod ends and box at NAPA, the prices are reasonable and the parts are of high quality.
Old Jan 27, 2009 | 05:21 PM
Beamed's Avatar
Beamed
have any of u guys rebuilt ur steering box and what about using some heim joints instead of tierodes?
