302 backfire issue
Old Jan 26, 2009 | 06:03 PM
stroked bronco's Avatar
stroked bronco
302 backfire issue
i've got a '90 302 out of an f250 in a 83 jeep cj8. transplanted engine computer and wiring harness. edlbroc performer heads, comp roller cam and rockers. been through valve adjustment several times and checks good everytime. compression is a solid 150 on all 8. truck seems to run fine with the exception of exhaust backfire and intake backfire on heavy acceleration. also hesitation from take off under heavy accelleration. oddly engine seems to run ok w/ map unplugged however tested w/ a known good map and no change.
Old Jan 26, 2009 | 06:12 PM
taisa899's Avatar
taisa899
what's your timing set at?
Old Jan 26, 2009 | 06:20 PM
stroked bronco
i want to say about 10 btdc
Old Jan 26, 2009 | 06:26 PM
taisa899's Avatar
taisa899
with spout connector removed?
Old Jan 26, 2009 | 06:45 PM
stroked bronco
you know i was just thinking about that, i am not sure that the harness had the spout in it.
1988f2505.8
23
Oct 25, 2015 11:47 PM
brandonnichols
Mar 19, 2014 08:32 PM
GTS9MPG
26
Jan 21, 2014 11:56 AM
robjs111
1978 - 1996 Big Bronco
Oct 29, 2013 02:58 PM
MikeFlorida
Feb 18, 2007 05:23 AM
