Sponsored by: Kumho
Need six-inch blocks
Old Jan 26, 2009 | 02:50 PM
cgrandahl64's Avatar
cgrandahl64
I need six-inch rear blocks for the back of the truck in my sig. Right now the stock 4” are in. Any Idea where I can get some? I found a set online for $225 and I want to avoid spending that type of money..
Any help would be great.
Old Jan 26, 2009 | 05:46 PM
75F350's Avatar
75F350
Holy axle wrap batman. DO you really want 6 inch blocks?
Why not upgrade your leafs? Not expensive if you have your existing units re-built with a little more lift.
Old Jan 26, 2009 | 05:50 PM
andym's Avatar
andym
I agree. You don't want blocks that big.
Old Jan 27, 2009 | 04:26 AM
Bender99's Avatar
Bender99
How do you rebuild them with more lift? Are you talking about add a leafs or helpers?
Old Jan 27, 2009 | 09:20 AM
75F350's Avatar
75F350
A spring shop can re-build an existing spring pack and add more arch to them. This will provide more lift. In addition the spring shop can add more leafs that are thinner than the originals. This will make a larger pack so weight capacities are not compromised, and the larger dimension will add additional heigth as well, but having thinner leafs will not require a sacrifice in ride. Having spring packs re-built is not uncommon, nor is it really expensive.
Add-a-leafs just add resistance, and while it does add lift, does so ata compromise in ride quality.
Helper leafs do not offer any lift, and are typically seperate from the priginal leaf pack, and only offer additional resistance when the original spring flattens out due to excessive loads, or when load capacities of the leaf have been reached.
